If you're having problems connecting to your broadband there are some things you can do at home to try and resolve it.
Learn how to set up your BT Hub for BT Broadband.
Connecting to your BT Hub with wires gives you the fastest and most reliable broadband connection.
Go back to: What type of connection problem are you having?
