Back
Set up your BT hub with fibre
BT Home Hub 3 or BT Home Hub 4
If you've got fibre broadband and a Home Hub 3 or Home Hub 4, you'll need to use an Openreach modem to get set up.
Download the user guide or follow these steps:
Your master socket is a small white box, usually located near the front door.
It’s better to use your master socket rather than an extension socket. The broadband signal will be stronger and more stable.
On activation day unplug all your old broadband equipment and send them back to us to avoid any charges.
Insert one end of the grey broadband cable into the DSL socket on your Openreach modem. Insert the other end in to the master socket. Make sure each end is fully pushed in - you'll hear a click.
Then, connect the white power cable to your Openreach modem and your power socket. Turn the power on at the wall, the Power and DSL lights should come on.
Connect your Hub and Openreach modem using the Infinity cable (the black cable with red ends.) Insert one end into the LAN 1 socket on your Openreach modem. Insert the other end in to the BT Infinity socket.
Then, connect the black power cable to your Hub and your power socket. Turn the power on at the wall.
Press the Power button to turn the hub on. The lights on the front will turn blue when it is ready, which could take at least three minutes.
If the lights don’t turn blue, use our hub light guide. Remember your broadband can go live up to midnight.
Your network name and password are on the back of your hub, your network will be called something like BT-XXYYXX.
On your device search for your network and enter your password exactly as it is shown. Wait a few moments for it to connect.
Your broadband speeds may fluctuate for up to 10 days while we perform tests to ensure you get the best possible speeds and connection.
Make sure you keep your hub on all the time. If you turn it off, we might think there is something wrong with the line.
Connect your devices
Whether it's your phone, tablet or console, find out how to connect to your new wi-fi network.
Connect your device to wi-fi
Broadband speeds
There are simple ways you can boost performance and get the best from your broadband.
Try our broadband speed tips
Manage your account
Download the My BT app to check your bill, test your speeds and activate your internet security products.
Download the My BT app on iOS Download the My BT app on Android
