Back
Connect your devices to BT Broadband
Connect devices
To connect using wi-fi you need your network name and password.
Android
1. Go to Settings - Network & internet.
2. Turn on wi-fi.
3. Select your hub from the list of networks.
4. Enter your password and tap ‘Connect.’
5. Wait for your device to connect.
Apple
1. Go to Settings – Wi-Fi.
2. Turn on wi-fi.
Back
Android
2. Turn on wi-fi.
Apple
2. Turn on wi-fi.
Back
Windows 7
1. Click the wi-fi icon on the taskbar - it looks like wi-fi signal bars.
2. Select your hub from the list of networks  Click ‘Connect.’
3. Enter your password and click ‘Connect.’
4. Wait for your device to connect.
Windows 10
1. Click the Network icon on the taskbar - it looks like signal bars.
2. Select your hub from the list of networks. Click ‘Connect.’
3. Enter your password and click ‘Next.’
Windows 8
1. Click the Internet access icon on the taskbar - it looks like signal bars.
2. Turn wi-fi on.
3. Select your hub from the list of networks. Click ‘Connect.’
4. Enter your password and click Connect.
Mac OS
1. Click the wi-fi icon on the menu bar.
3. Enter your password and ‘Connect.’
Back
Windows 7
Windows 10
Windows 8
2. Turn wi-fi on.
Mac OS
Back
Xbox One
1. Press the Xbox button.
2. Go to Profile & system – Settings – General – Network settings.
3. Click ‘Set up wireless network.’
4. Select your hub from the list of networks.
5. Enter your password.
6. Wait for your device to connect.
7. Check everything is working by going to Network settings and selecting ‘Test network connection.’
Xbox 360
2. Go to Settings – System – Network settings.
4. Enter your password and select ‘Done.’
5. Wait for few moments, then your device should be connected.
PlayStation 4
1. Go to Settings – Network – Set up Internet Connection.
2. Select ‘Use Wi-FI’ and choose Easy.
4. Enter your password.
5. Wait for a few moments. If you connect successfully ‘Test Internet Connect’ will appear.
Nintendo Switch
1. Open the Home menu and tap ‘System Settings.’
2. Go to Internet - Internet Settings.
5. Wait for a few minutes, while the Switch connects. When the process is complete tap OK.
Back
Xbox One
Xbox 360
PlayStation 4
Nintendo Switch
Back
Amazon Echo
To connect your Amazon Echo smart speaker you’ll need to download the Amazon Alexa app for Android and Apple devices and follow the instructions. Make sure your phone or tablet is connected to your home network.
How to set up your Amazon Echo >
Google Home
To connect your Google Home smart speaker you’ll need to download the Google Home app for your Android or Apple devices and follow the instructions. Make sure your phone or tablet is connected to your home network.
How to set up your Google Nest or Google Home >
Set up Complete Wi-Fi using the My BT app, you’ll also need a BT ID.
Need more help?
