Back
How can I change the Wireless Network Name (SSID) and Wireless Password/key?
You can change your network name and password from either the app or a web browser:
From the app:
  1. Select Settings and then Network Name. The current network name is displayed, select Change Network Name
  2. Enter your new network name and password and then Save
From a web browser:
  1. Make sure you are connected to your Whole Home Wi-Fi network
  2. Enter http://mybtdevice.home in your internet browser address field
  3. Enter your Admin password then click Login (Admin password is printed on your wireless settings card located on the back of your discs)
  4. Select Settings then Wireless
  5. Enter your new network name and password and click on Save
Please note: when you Save your new wireless settings you will be disconnected from the network. Go to your device’s Wi-Fi settings and enter the new details to reconnect to your Whole Home Wi-Fi network.
Thanks for your feedback
Submit
Need more help?
