Video- How to connect to your test socket
If you're having trouble with your broadband connection there are a few simple tests to work out if the problem might be with your home set-up or equipment rather than with the BT network.
Our video demonstrates how your Hub should be connected and provides some simple checks to perform.
Thanks for your feedback
Submit
Need more help?
