Back
All about Call Waiting
What is Call Waiting?
Call Waiting tells you when other callers are trying to get through. You'll hear a discreet beep when someone is trying to get through to you while you're on the phone. You can choose whether or not to take the call.
You can also add it to a Calling Features Pack, if there are other Calling Features you'd like to use. You can order it online now and check out our other calling features at www.btcom.ll-digital-sandbx1.bt.com/callingfeatures >
How much does it cost?
The monthly cost depends on how many calling features you have from those offered in the Calling Feature Pack. A 30-day minimum term applies. Line Rental Plus customers can choose to opt in to take the Calling Feature Pack at no extra cost.
  • One Calling Feature - £6.36 a month
  • Two to four Calling Features - £11.26 a month
  • Five or more Calling Features - £17.74 a month
How do I get it?
You can easily add or remove Calling Features online >
How do I check whether Call Waiting is on?
To check whether Call Waiting is on, press the star key (*) on your telephone keypad followed by the hash key (#). Enter the number 43 and finish by pressing the hash key.
Please remember: Switch off Call Waiting if you want to use a fax or modem on the same line. Call Waiting is not compatible with Internet Call Waiting.
How does Call Waiting work with Voicemail?
If you have the Voicemail service and are on a call when a new incoming call arrives, an intrusion tone will advise you that a new call is waiting.
The caller will hear the Call Waiting announcement, and, if you decide not to take the new call, after 21 seconds it will be diverted to the Voicemail service.
How do I switch between callers while using Call Waiting?
While you're using Call Waiting, you'll hear a beep to let you know that you have a second caller waiting to speak to you.
To switch to your second caller, simply press the recall button on your telephone keypad. To return to your first caller, press recall again. When you've finished your call, just hang up.
How do I switch Call Waiting on and off?
To switch on Call Waiting, press the star key (*) on your telephone keypad followed by 43, and then the hash key (#).
To switch off Call Waiting, press the hash key, 43, and then the hash key again.
Documents
BT Calling Features user guide (PDF doc, 170KB).
Get Adobe Reader You will need Adobe Reader to view PDF documents.
Thanks for your feedback
Submit
Need more help?
