BT Mobile: How do I order and activate a replacement SIM?
You can order a replacement BT Mobile SIM online at www.btcom.ll-digital-sandbx1.bt.comreplacesim >
Or if you can't get online, give us a call on 0800 800 150.
Once you've received it, make sure sure you activate your replacement SIM >
Thanks for your feedback
Submit
Need more help?
