Back
How do I pick up my BT Mobile voicemail from abroad?
Before you can use your phone abroad, you need to make sure roaming is turned on. To check, go to the "Manage what you spend" section at www.btcom.ll-digital-sandbx1.bt.com/mymobile >
To pick up your voicemail abroad you need to set up a voicemail PIN before leaving the UK. To do this, access your voicemail in the UK and follow the voice prompts.
When international roaming is switched on and you've set up a PIN, here's how to get your voicemail:
  1. Dial your own BT Mobile phone number
  2. Press * when the voicemail announcement starts
  3. Enter your PIN
Thanks for your feedback
Submit
Need more help?
