How to change APN settings on a BlackBerry
Here's how to change APN settings on a BlackBerry.
  1. Go to Settings
  2. Select Network Connections
  3. Select Mobile Network
  4. Select APN
    Put in the following settings:
    • Access Point Name (APN): btmobile.bt.com
    • Username: bt
    • Password: bt
  5. Now press Save
To set the MMS APN:
  1. Swipe left to right
  2. Access The Hub
  3. Select Text Messages
  4. Select Menu (...)
  5. Select Settings
  6. Select Text Messages
  7. Select Advanced
  • APN: btmobile.bt.com
  • Username: bt
  • Password: bt
  • MMSC URL: http://MMS/
  • Proxy URL: 149.254.201.135:8080
  • Proxy Username: leave blank
  • Proxy Password: leave blank
  • Maximum Message Size: 307200
Make sure that all the settings are correct and then then click Save.
Thanks for your feedback
Submit
Email this page
Need more help?
