Back
What to do if you're having trouble using Wi-Fi Calling
To help us fix things, we need you to collect some information for our technical team.
We need three examples of the issue you're experiencing in at least two different locations. For each example we need to know:
  1. Date and time
  2. Full postcode of where you were at the time
  3. The number you were calling, or that was calling you
  4. Was the call successful?
  5. If not, exactly what happened?
  6. Because this is a Wi-Fi Calling issue, we also need to know:
  7. Internet provider
  8. Wi-fi uplink speed - that's the speed from your device to the hub/router
  9. Wi-fi downlink speed - the speed from the hub/router to your device
  10. You can test the uplink and downlink speeds using one of the free apps that's available. Simply type "WiFi Speed Test App" into your search engine, download the app you want and follow the instructions.
    If you can (especially if you're a BT Broadband customer), we also need:
  11. Hub/router make and model
  12. Hub/router Firmware version
  13. If you're a BT Broadband customer, go to Help for BT Hubs for help with finding the make and model. And to find the Firmware version, go to http://192.168.1.254/ and click the Status box
  14. We also need a contact number for you, in case we need to speak to you for more information
When you've got this information for three examples, please call us back on 0800 800 150 and we'll investigate for you.
Thanks for your feedback
Submit
Email this page
Need more help?
