Back
Channels leaving BT TV in 2021
From spring 2021, a few channels won’t be in non-flexible BT TV packages anymore.
Some of these won’t be in any of our packages going forward, others will only be in flexible TV packages
Sky History
Removed on
1 March 2021
Recordings lost on
31 March
Available in flexible packages
Sky History 2
Removed on
1 March 2021
Recordings lost on
31 March
No
Crime and Investigation
Removed on
1 March 2021
Recordings lost on
31 March
No
Lifetime
Removed on
1 March 2021
Recordings lost on
31 March
No
SyFy
Removed on
1 April 2021
Recordings lost on
4 May
E!
Removed on
1 April 2021
Recordings lost on
4 May
No
Channel
Removed on
Recordings lost on
Sky History
1 March 2021
31 March
Sky History 2
1 March 2021
31 March
No
1 March 2021
31 March
No
Lifetime
1 March 2021
31 March
No
SyFy
1 April 2021
4 May
E!
1 April 2021
4 May
No
Is there any way to keep a channel I like?
If you want to keep a channel that's in our flexible packages (shown in the table above), you can. Just switch to a flexible TV package.
If not, you might want to take a look at our flexible packages anyway. You'll probably find a different channel with similar shows.
Can I still watch my recordings?
After a channel ends, you'll have a few weeks to watch the shows you recorded from that channel. Make sure you catch them before they're gone (dates shown in the table above).
Thanks for your feedback
Submit
Need more help?
