Back
BT Ultra HD (4K TV)
Ultra High Definition (UHD) allows you to view picture in stunning quality. You’ll get four times the detail of High Definition (HD), plus richer, deeper colour.
What’s the difference between UHD and HD?
  • Four times the pixels (8.29m vs 2.07m)
  • Superior picture quality (50 frames per second vs 25)
  • Richer, deeper colour (10-bit detail vs 8-bit)
  • With BT UHD you get our 4K recordable TV box which has a 500GB memory. So you can record up to 300 hours of SD TV, 125 hours of HD TV or 30 hours of UHD TV
What will I get with UHD from BT?
  • An exclusive, dedicated BT Sport Ultimate channel, showing the best of BT Sport
  • A 4K recordable TV box (only available on BT) which comes with 500GB storage
YouView+ box
What do I need to get BT UHD?
How do I order BT UHD?
Visit www.btcom.ll-digital-sandbx1.bt.com/tv > or call us on 0800 917 7614.
More about UHD from BT
No, you can do it yourself. If you can’t connect your 4K recordable TV box directly to the BT Hub using the Ethernet cable, you can use Mini Connectors which plug into the socket. You can buy them from the BT Shop >
UHD won’t work using older broadband extenders and powerline adaptors.
If you’d prefer an engineer to install it you can order this, but there’ll be a charge. The engineer can also hardwire your TV box to your Hub to give you the best connection.
On average we'll be showing one live event a week throughout the season - that’s across all of our sports events.
As well as the BT Sport Ultimate channel, you’ll also be able to watch our entertainment channels , Catch Up TV, Kids, HD and UHD content.
Find out what channels are included in all of our BT TV packs >
Yes. Like On Demand programmes, the UHD channel is sent over your broadband connection.To watch UHD On Demand content and the UHD channel, your broadband must be working.
There's less broadband speed available for other services when you're watching the BT Sport Ultimate channel. So when you've finished viewing an UHD programme, it’s best if you change to a Freeview channel.
No, not if you watch through your 4K recordable TV box. Watching UHD content through other services (like YouTube) will count towards your broadband usage. So you might be charged depending on the package you’ve got.
Yes, the BT Sport Ultimate channel is included in the Connected Red Button application.
More about the 4K Recordable TV Box
The main difference between the recordable and 4K recordable TV box is that the 4K recordable TV box can play Ultra HD content, as well as Standard Definition (SD) and High Definition (HD). The recordable TV box can only play SD and HD.
You can watch and record the BT Sport Ultimate channel in the same way as your Freeview channels. When you’ve got enough line speed, you'll be able to watch an UHD channel at the same time as recording another HD Extra TV channel. If you start having trouble with picture quality, try watching or recording in SD instead.
The 4K recordable TV box comes with 500GB of storage. You can record up to 300 hours of SD TV, 125 hours of HD TV and 30 hours of UHD TV.
Yes. UHD recordings will fill up your hard disc drive quicker than SD and HD recordings.
No. It would affect the picture quality too much to support two boxes with UHD subscriptions on both.
But you can have a TV or recordable TV box as your second one instead.
If you have a surround sound system you'd like to use, make sure it supports UHD/4K pass through with HDCP 2.2.
If it doesn't, we recommend you use the Audio Return Channel (ARC) from your TV to connect your sound system to.
Yes. You'll need to take our Total Entertainment or Max BT TV package, and have an UHD/4K TV in order to watch Netflix UHD.
I'm watching Netflix through an app on my Smart TV - will this affect how much of my broadband allowance I use?
Watching Netflix through your Smart TV or other gadgets counts towards your broadband usage. If you now start watching Netflix through your 4K recordable TV box, it won't count towards your broadband allowance.
More information if you've already got BT TV
No, unfortunately broadband extenders and powerline adapters don’t work with UHD. You'll need to replace them with Mini Connectors or arrange a chargeable engineer installation.
No, the recordings are saved to the hard drive on your box so we can't transfer them.
Yes. When you get the Max or Total Entertainment package, you’ll need to renew your TV contract for another 12 months. You might also need to renew your broadband contract if you have less than 12 months left on your current one.
You'll need to sign up to the Max or Total Entertainment package to get UHD content.
Thanks for your feedback
Submit
Need more help?
