Can I connect my surround sound system to my BT TV box?
Yes, you can connect your TV box to a Surround Sound system using either a TOSlink cable or an HDMI cable. However, some programmes may not be available in Surround Sound.
Press the Information button on the TV remote control button on your remote control to find out whether the programme supports Surround Sound. You'll see a '[SS]' symbol in the programme description if it does.
Connecting with a TOSlink cable
  • Connect the TOSlink cable between the S/PDIF socket on your TV box and the Digital Optical In port on your Surround Sound system
  • To enable Surround Sound on your TV box, press the Home (or YouView) button on the remote control. Go to Settings > TV Signal & Quality  > S/PDIF Audio Format and change from 'STEREO' to 'SURROUND'
Connecting with a HDMI cable
  • Connect the HDMI cable between the HDMI socket on your TV box and the HDMI socket on your Surround Sound system
  • To enable Surround Sound on your TV box, press the Home (or YouView) button on the remote control. Go to Settings > TV Signal & Quality > HDMI Audio Format and change from 'STEREO' to 'SURROUND'
  • Enabling Surround Sound through HDMI will set your box volume to 100% and volume controls will be disabled. You'll have to adjust the volume on your Surround Sound system or TV
What is SPDIF / Optical out?
Optical out or SPDIF lets you connect your BT TV box to a 5.1 Dolby surround system.
Thanks for your feedback
Submit
Need more help?
