Back
Controlling your BT TV box using a plug in keyboard
If you find using the TV remote control difficult, a plug in UK USB keyboard can be used instead. Keyboard key mapping is used to support popular accessible keyboards.
This currently works with the keyboards below. Click on the keyboard you use, to see which keys replicate your remote control buttons:
The keyboard can be used in conjunction with the remote control, or as a substitute. This works across the YouView menus, including the On Demand players.
Thanks for your feedback
Submit
Need more help?
