Back
Finding and watching On Demand programmes on the BT TV App - Web
You can find On Demand programmes in the genre discovery screens; Entertainment, Sport, Film, Box Sets and Kids.
These screens show genre-specific On Demand programmes. You can also find genre-specific live channels in these screens too.
Entertainment screen on the web showing TV shows
You can also use the search function to find your On Demand programmes.
Screen on the web showing the search box so you can find your On Demand programmes
Watching On Demand programmes
When watching an On Demand programmes, you can pause, rewind and restart the episode using the progress bar.
Screen on the web showing the pause, rewind and restart options using the progress bar at the bottom
You can also see synopsis information for the programme you're watching by pressing the i button.
Screen on the web showing synopsis information for the programme you are watching
And by pressing the three squares, you can see other episodes for the programme you're watching if it's part of a series.
Screen on the web showing other episodes for the programme you are watching if it is part of a series
If the programme you’re watching is part of a series, a countdown will appear near the end of the episode and the next episode will automatically play. You can press Play now to start the next episode straight away.
Screen on the web showing the Play Now button to start the next episode straight away
Thanks for your feedback
Submit
Need more help?
