Before looking for your error code, why not try our TV and Sport help tool? The help tool can quickly get you back up and running again. Simply click the link below and give it a go. If................
If you'd like to look up the code, please type the full error code in the box below.
For example: SM001
SP920
Your existing internet connection isn't supported. Please try a different connection.
SH113
Please try again later.
SP935
Please use a different device.
SB011, SB012, SB013, SB901, SB907, SB910, SB915, SB921, SB923, SB927, SB929, SB999, SH110, SJ102, SJ103, SJ104, SJ105, SJ112, SJ113, SJ117, SJ115, SJ116, SJ116, SJ114, SJ921, SJ999, SN003, SP080, SP081, SP082, SP087, SP088, SP089, SP098, SP901, SP902, SP903, SP906, SP907, SP910, SP911, SP914, SP915, SP916, SP917, SP919, SP921, SP925, SP927, SP929, SP930, SP932, SP936, SP937, SP938, SP999, SE025, SE026, SE027, SE028, SE029, SP996, SP997, SP998, SO027, SN003, SN003, SP102, SC001, SC002, SC003, SJ901, SJ902, SJ903, SB929, SP967, SP514, SO060, SB002, SB003, SB004, SB021, SB022, SB023, SB010, SO061, SO099, SP090, SP091, SP092, SP105, SP107, SP108, SP112, SL033, SL035, SL036, SL034, SL032, SL031, SM004, SM005, SM006, SM007, SM008, SO999, SP104, SP113, SP995
To fix this error, try restarting the app by pressing Exit and then re-opening the app.
If you press the Smart Hub button, the app will stay open and won't restart fully.
SJ939, SP939
You need to update your operating system (OS) to the minimum supported version.
SJ107
Please wait 15 minutes, then try entering the details again.
SB020
This problem is caused by trying to enter a device name for your registered devices with either invalid or no characters. Try using a different device name.
SB930, SB951
We're having a problem with the registered device you're using. Try closing the app and restarting it. If you keep seeing this error, you may have to get in touch with us to take a closer look at your account.
SJ900, SJ910, SJ911, SJ914, SJ931
SL906, SP956
You need to have BT TV App Extra to watch on the device you're trying to watch on. You can find out more information about App Extra here >.
SJ940
The device you're trying to watch on isn't supported by the BT TV App. You'll need to try using the app on a different device. For more information on supported devices, go to bt.com/help/tv >
SP110, SP106
This error is due to a problem with your internet connection. Make sure you're fully connected to the internet, and then try again.
SP111
You'll see this error if you've left a programme paused for more than half an hour. Click on the programme you were watching to pick up from where you left off.
SP928, SP933, SP958, SP959
You've reached the maximum amount of devices you can have registered on your account. You can change a registered device once every thirty days in the 'Device Management' screen within the 'Settings' menu.
If you've changed your device in the last thirty days, you'll see a countdown at the top of the 'Device Management' screen that shows you how long you have before you can change it to another one.
SS008, SS009
This means you're using a Virtual Private Network (VPN) or equivalent location disguising service. The BT TV App isn't compatible with these types of services, so you'll need to swtich them off to use the app.
SW001
Downloads aren't supported on this device. Please go to bt.com/help/tv > for information on compatible devices.
SD002
There was a technical issue in starting playback of the programme you're trying to watch. You can fix this by exiting the player, and then playing the programme again. If the problem continues, restart the app and try again.
SG001
The device you're trying to open the link on doesn't have a browser that can support it. Try using a mobile or tablet to open the link.
SO053, SO050, SO052
There's a problem with the link we're trying to take you to. Try restarting the app and pressing the link again. If this doesn't work, it may be something we have to fix in the background. Come back later and try again.
SW125, SW126
Our licence from our content partners for this title has expired, which meaans you'll no longer be able to watch it. We'll be removing it from the service shortly.
