A quick and easy guide to show you how to set up your BT TV.
Learn all about BT's specialist TV aerial install partner called Total Support Group (TSG).
Find out what the two different BT TV PINs are and how to change them.
Everything you need to know about our BT Mini Connectors kit, which connect your BT TV box to your BT Hub without the need for wires.
Audio description describes what's happening on the screen. Here's how you can turn it on or off, or change the volume.
Go back to: What can we help with?
