Back
Audio Description on your BT TV box
This setting provides an audio narrative describing what's happening on the screen.
You can tell which programmes have Audio Description by pressing the 'i' button on your remote control. You'll see 'AD' in the programme summary if there's Audio Description.
To turn Audio Description on, press the AD button on your remote control, or press the main menu button. Alternatively, if you have the TV Box Pro, press the MORE button on your remote (top right hand button with three horizontal lines).
Then go to Settings > Accessibility & Language > Audio Description. Choose your preferred setting and go to Done.
New BT TV audio description
Changing volume levels for the Audio Description
To adjust the volume of your Audio Description, go to Settings > Accessibility & language > Audio Description. Select Volume and choose your preferred option, then go to Done.
Change audio description volume on new BT TV
Thanks for your feedback
Submit
Need more help?
