Back
How do I manually update software on BT TV boxes?
You can check if a software update is available manually at any time by going to:
  • Settings > Software Information > Update software
  • And:
  • Settings > Software Information > Update players and apps
If an update is available, your TV box will then download it automatically.
However your TV box will update its software automatically on a regular basis if it’s connected to the internet. To receive automatic software updates, leave your box in standby and your Hub connected.
Thanks for your feedback
Submit
Need more help?
