This box is an older version of the BT TV Recordable Box G4.
The two are identical in what they can do. All the menus and features are exactly the same, but the most recent version of the box is smaller than this earlier version.
There are three recordable TV boxes and two non-recordable TV boxes. So how are they different? Click through the boxes below for a full comparison.
BT TV Box Pro
BT TV Recordable box
BT TV 4K Recordable box
With the BT TV Box Pro you can:
Additional information
With the BT TV Recordable Box G4 you can:
This box does everything the BT TV Recordable Box G4 does, but has the added feature of Ultra HD.
If you have an Ultra HD/4K TV, this box will allow you to watch Ultra HD content available with the Total Entertainment or Max packages.
With the BT TV 4K Recordable Box G5 you can:
Find out more about BT Ultra HD >
BT TV Box Pro
BT TV Box Mini
BT TV Box
The BT TV Box Mini is our smallest box. It does most of the things that the BT TV Box Pro does, except that it does not have an aerial input and therefore requires an internet connection via Wi-Fi or Ethernet connection to watch Freeview content. The BT TV Box Mini is also a non-recordable device.
With a BT TV Box Mini you can:
Differences to a BT TV Box Pro:
The BT TV Box Z4 is our smallest box. You can’t record live TV on this box, but it does most other things that a BT TV Recordable Box G4 can do
With a BT TV Box Z4 you can:
Differences to a BT TV Recordable Box G4:
BT TV Box Mini
BT TV Box
