Back
Transparent backgrounds on your BT TV box
This allows you to still see what's going on in the background while you browse the menus.
To switch this feature on, press the Home (or YouView) button on your remote then go to SettingsĀ > Accessibility & LanguageĀ > Appearance. Select Transparent backgrounds and change this to On, then go to Done.
Transparent abckgrounds on new BT TV
Thanks for your feedback
Submit
Need more help?
