Back
Ultra HD compatibility and set up on your 4K TV
To watch BT's Ultra HD content, and to get the highest possible picture quality, you need to check you have (or plan to buy) an Ultra HD/4K TV that's compatible with our Ultra HD service.
Most TV models from 2016 onwards should be compatible, but you should check that your TV has the following:
✓ An HDMI 2.0 port
✓ HDCP2.2 content protection
✓ A picture resolution of 2160p50 (sometimes known as 50Hz)
If you have an older model TV, you can find some compatible models here >
If you’re worried about compatibility, please check your TV manufacturer’s product information to verify.
Ordering BT Ultra HD
Brand new to BT? Get a package here >
Got fibre broadband, but not BT TV? Order BT TV with Ultra HD here >
Already got BT TV? Upgrade to an Ultra HD package here >
Thanks for your feedback
Submit
Need more help?
