I've opened my app and one or more discs are showing red status but the actual disc is showing blue LED status
Please make sure the 1st disc is connected to the router using the Ethernet cable supplied and try rebooting all the discs (turning each disc off and then on again).
If this doesn’t work, please factory reset all discs and re-install. For help see: How can I reset my Whole Home Wi-Fi to the default settings >
Thanks for your feedback
Submit
Need more help?
