BT4000 Big Button
Product details
Cordless telephone
  • Easy to read 1.8" full graphic dot-matrix display with amber backlight
  • Hearing aid compatible with Amplify button to boost volume when you need it
  • Avoid Nuisance or Unwanted Calls with options to block calls by specific numbers or certain call types*
  • Handsfree speaker
  • Save up to 100 contacts that will automatically synchronise between handsets (twin pack or more required for contact synchronisation)
  • Available in single and twin packs
  • Up to 300m range
  • Up to 16 hours talk and 180 hours standby time
* You need to have a Caller Display service from your network provider to block nuisance calls and for Visual Voicemail feature. Charges may apply.
BT4000 Big Button
Documents
Thanks for your feedback
Submit
Need more help?
