BT3110 Nuisance Call Blocker
Product details
Cordless phone with nuisance call blocking and answer machine.
  • Blocks up to 50 numbers
  • Excellent sound quality
  • Easy set up
  • Handsfree speaker
  • Long range reception, up to 300m outdoors, 50m indoors
  • Ten hours of talking or 100 hours standby time
  • See and hear if you have a second call waiting
  • Easy to read screen shows when you have messages
  • Dedicated Do Not Disturb button
  • Save up to 50 contacts
  • Redial any of the last ten calls you made
  • Record up to 12 minutes of messages
  • 1.6 inch blue backlit screen
To block nuisance calls or use text messaging and visual voicemail features, you need Caller Display from your network provider. Charges may apply.
Documents
Thanks for your feedback
Submit
Need more help?
