BT7610 Nuisance Call Blocker
Cordless telephone with answering machine: Easy to read 1.8" full graphic dot-matrix display with amber backlight, Greater call control with options to block calls by specific numbers or....
Product details
  • Easy to read 1.8" full graphic dot-matrix display with amber backlight
  • Greater call control with options to block calls by specific numbers or certain call types*
  • Handsfree speaker
  • Send text messages from your landline*
  • Up to 30 minutes answering machine recording time
  • Save up to 200 contacts that will automatically synchronise between handsets (twin pack or more required for contact synchronisation)
  • Available in single, twin, trio and quad packs
  • Up to 300m range
  • Up to 12 hours talk and 120 hours standby time
* You need to have a Caller Display service from your network provider to block nuisance calls and for text messaging features. Charges may apply.
BT7610
This product has recyclable packaging
Documents
Thanks for your feedback
Submit
Need more help?
