Can I use a different type of BT cordless phone with my existing base?
To find out if you can use a different type of BT cordless phone with your base, you need to know if it is GAP compatible. To check, go to the user guide for your phone. If your phone is not GAP compatible, you can only use extra phones that are the same model. If your phone is GAP compatible.......
To find out if you can use a different type of BT cordless phone with your base, you need to know if it is GAP compatible. To check, go to the user guide for your phone >
If your phone is not GAP compatible:
  • You can only use extra phones that are the same model with your base
If your phone is GAP compatible:
  • You should be able to register your phone to the base but it is not guaranteed that all features will work
  • Phones that are GAP compatible are only required to:
    • make and receive calls
    • ring for incoming internal, external and paging calls
  • In most cases, the phone will show Caller Display information but it is not mandatory
There is also a limit to the number of phones that you can register to a base. For more information, see the user guide for your phone >
To say thank you... Our existing customers can enjoy exclusive offers on a wide range of products. See offers
Thanks for your feedback
Submit
Need more help?
